Engine Power Reduced / Power Steering / Low Fuel / Service Airbag Message
Old 12-23-2014, 07:04 AM
desmonda's Avatar
Im at about 225,000 miles, just recently i started my car HHR Lt 2.2L Auto. the power steering and service airbag message shows, but when i press the gas pedal the engine power reduced message shows along with the cel and the car starts to shift hard. After driving a miles or so the low fuel message show then the car cuts off.
Is this a sign i should get a new vehicle, this is the first major problem i had since 23,000 miles.
desmonda is offline
Old 12-23-2014, 07:27 AM
Lucky's Avatar
Welcome to the site
First thing I would do is to get the codes read and have the battery tested.
I wouldn't wright the car off yet.
Lucky is offline
Old 12-23-2014, 07:57 AM
LawDog88's Avatar
Originally Posted by Lucky
Welcome to the site
See bolded section above. That sounds like it may be contributing to it.
Also, as Lucky said get the codes read.
We cannot offer much other than blind advice without the codes.
LawDog88 is offline
Old 12-23-2014, 12:12 PM
Technical Moderator
Also look at the red wire connection to the Underhood fuse box and the ground on the radiator support. Not to mention the obvious tightness of the upper and lower fuse box halves connection.
donbrew is offline
Old 12-23-2014, 04:36 PM
Welcome to the site, follow these steps as posted and please post the code only IE.. P0000, as most times the AZ guy tells you his interpretation which could be wrong and cause a sore arm and shoulder fr throwing money at your car.
Oldblue is offline
Old 12-23-2014, 08:17 PM
desmonda's Avatar
I had the car followed to autozone and got a few codes actually
P0301
P0304
P0351
P0354
P0462
P0458
P0638
P1516
P2120
desmonda is offline
Old 12-23-2014, 08:40 PM
LawDog88's Avatar
Have you by chance plugged these into google to see what you get?
LawDog88 is offline
Old 12-24-2014, 07:43 AM
Technical Moderator
You have an electrical problem. Seems to be related to cylinder 1 & 4.
If you have looked at the fuse box connections. Now look at all of the engine wiring harness for chafing,burning, touching exhaust pipe or any sign of wear.
donbrew is offline
chevhhrdummy
09-30-2014 07:48 PM
tucsondivots
03-23-2014 04:38 PM
mjr101155
01-05-2014 04:55 PM
Velocity12
01-23-2013 09:19 AM
X_EGO_BRAIN_X
03-28-2011 10:32 PM
Quick Reply: Engine Power Reduced / Power Steering / Low Fuel / Service Airbag Message
