engine reduce power
engine reduce power
i have a 2007 chevy hhr 2.4 once in the past this light has come on and dropped my speed to about 25, turned off radio and gps. it was the battery
the light has once again come on
my battery, and alternator are testing good
its pulling code p0010, p0011, p0641
which has to do with the intake camshaft sensor.
is that sensor causing enough damage to make the car go into reduce power or do you think there is another issue?
Any advice is greatly appreciated!
Here's whopper's "How To" thread on the camshaft solenoids...
https://www.chevyhhr.net/forums/how-tutorial-library-21/camshaft-position-actuator-solenoid-valve-replacement-w-pics-p0010-11-p0013-14-a-28779/
The P0641 code is "5 Volt Reference Voltage Incorrect"
Which can be any of the following.
- Faulty Engine Control Module (ECM)
- ECM harness is open or shorted
- ECM circuit poor electrical connection
- Shorted sensor on 5 volt circuit
But it may be related to a bad solenoid, so I'd address them first, then clear the codes to see if the P0641 pops up again.
P.S. to the forum.
P.S. to the forum.
desmonda
12-24-2014 07:43 AM
chevhhrdummy
09-30-2014 07:48 PM
BunnyGirl
07-06-2014 01:16 PM
ahuschka
08-25-2013 07:22 PM
