Rough Running
Take it to your local auto parts store, Napa/Autozone/Advance/etc, and have the codes pulled. Once you get them, post them here and we'll have a better idea of what direction you should look in to fix the issue.
X2 - without downloading the code from the engine check light, anything we can suggest would be a total guess. If the car is not drivable to the autoparts store, borrow a OBDII code reader (it must be CAN-compatible in order to get the codes to download).
bigjacksauto
2.0L Performance Tech
61
08-21-2013 04:51 PM
