Exhaust Leak
Old 12-17-2011, 07:10 PM
db/sb's Avatar
Here's how one of our members solved that problem:
https://www.chevyhhr.net/forums/how-tutorial-library-21/how-repair-flex-pipe-31536/
db/sb is offline
Old 12-17-2011, 08:39 PM
Good find there db/sb, I was looking for that to link up here.
843de is offline
Old 12-17-2011, 09:22 PM
AJochum's Avatar
Nice! What I like is (if I'm reading it right) is that the bolts line right up with the exhaust manifold of the HHR.
Someone could make a LOT of money if they just produced what he did but all fitted.
By the way - getting those three nuts off is a bear. Not a ton of room under there, especially without a lift and mine are totally torqued on tight. Will require heat and double-jointed arms.
AJochum is offline
Old 12-17-2011, 09:45 PM
db/sb's Avatar
The part exists but you'll still have to do some cutting and welding. Or have it done. I found these but I stopped my research when I found out that Chevy would fix ours under warranty. Here's a couple of links to them:
http://www.theflangeman.com/cgi-bin/...ion&key=FX2060
http://www.ebay.com/itm/Chevrolet-Co...item3cbf0dd071
db/sb is offline
Old 12-17-2011, 10:13 PM
AJochum's Avatar
Thanks for the leads. Monday I'm going down to my dealer and see if he can run it through warranty. If not, think I'll buy one of those. It would seem that it could be installed pretty easy, especially if they oversized/undersized the tubing so you could cut the pipe, slide it over and clamp it.
AJochum is offline
Old 12-18-2011, 04:53 PM
Technical Moderator
When I replaced the down pipe/cat, I had no problem getting the nuts off. I just put the car up on jack stands and used a 24" extension, if you are laying on your back it is a straight shot. The problems come in dis-connecting the electricals, that is a B.
You DO need to have a flexible section in that spot,
donbrew is offline
HMS
07-30-2014 08:21 AM
Izzy
11-24-2013 08:23 PM
hhrbeast07
06-10-2013 08:30 PM
calgaryhhr
10-22-2010 03:15 AM
Quick Reply: Exhaust Leak
