Fan not working.
Old 03-21-2017, 08:45 AM
ToniBob's Avatar
Fan not working.
I had My Check engine light come on recently and after a read it came up as a failed relay. I changed both the relay and the fuse for the cooling fan, but after reaching 220, turning on the AC, recirculating the air flow, it won't turn on and the engine light is still on. My next task is going to be wiring the fan directly to the battery(temporarily) to see if it still works at all.
If the fan runs, and has no bearing problems, what could be causing the problem?
2009 2.2 Automatic LS
ToniBob is offline
Old 03-21-2017, 08:49 AM
Technical Moderator
Year and model are important in this case.
donbrew is offline
Old 03-21-2017, 08:53 AM
Welcome to the site, I got 2009 from your profile, I'm guessing SS, but no any cures until I know for sure!
Oldblue is offline
Old 03-21-2017, 08:57 AM
ToniBob's Avatar
Sorry Y'all. 2009 HHR 2.2 LS
ToniBob is offline
Old 03-21-2017, 09:02 AM
Ah, well look for loose ground wire connections
https://www.chevyhhr.net/forums/prob...ing-fan-23808/
Oldblue is offline
Old 03-21-2017, 09:09 AM
Technical Moderator
I would guess a bad wire or a bad ground.
What is the code? It might tell you.
donbrew is offline
Old 03-21-2017, 09:46 AM
aradmahogany's Avatar
If it turns out to be the fan, its a very easy swap.
aradmahogany is offline
alfolsee2000
03-11-2022 09:22 PM
Teamecotec
03-06-2017 08:19 PM
RedTurboSS
03-16-2014 08:22 PM
JCJSS
11-03-2013 06:21 PM
PrairieHHR
06-23-2011 04:12 PM
Quick Reply: Fan not working.
