Feels like I'm driving in the wrong gear.
Old 01-09-2017, 03:00 PM
Sydnika's Avatar
So my car just started doing this. It's feels like I'm driving in the wrong gear until I hit 40mps then the car drives great. Just recently replaced the starter and fixed a water leak I had in the car. So what wrong now? It's 2009
Sydnika is offline
Old 01-09-2017, 03:07 PM
Check the ground wires above the starter and to the right , also check the TCM connections to ensure they are tight, clean and no frayed wires.
Oldblue is offline
Old 01-09-2017, 03:10 PM
Sydnika's Avatar
thanks. Will do
Sydnika is offline
Old 01-09-2017, 03:13 PM
Maybe explain "wrong" gear a little better. The RPM's too high ? Too low ? Have you counted the shifts from a dead stop up till speed ?
firemangeorge is online now
Old 01-09-2017, 03:18 PM
Sydnika's Avatar
My bad. It feels like I'm driving in the I instead Of D. But once I hit 40 it's OK. Or its sounds like I'm going really fast but I'm not really moving fast at all. If any of this makes sense.
Sydnika is offline
Old 01-09-2017, 04:29 PM
Answers to post #4 would help.
By the way. What ever became of your other problems ? The codes with the camshaft solenoids possibility and the "stuck in park" issue.
You were looking for a new mechanic but never answered back to those other threads you started.
Old 01-09-2017, 04:33 PM
Sydnika's Avatar
Sorry about that. I replaced the camshaft and the CEL went off. My brother did fixed the gear shift and now it's shifting again. I also replaced the starter.
Sydnika is offline
Old 01-09-2017, 04:59 PM
So all is well?
Oldblue is offline
Old 01-09-2017, 05:01 PM
Still no answer to post #4. Guess I'm done.
Fwiw. I highly doubt you replaced the camshaft. Camshaft position solenoid maybe. 2 completely different parts.
Old 01-09-2017, 05:33 PM
Technical Moderator
Is one of the many descriptions of a cracked flex pipe.
Are you looking at the tachometer, or just going by sound?
donbrew is online now
Quick Reply: Feels like I'm driving in the wrong gear.
