front left speaker volume incredibly low
Old 03-25-2015, 10:07 AM
oliver_cfc's Avatar
'06 HHR - everything stock - standard radio
When I leave the keys in the ignition and open the door, the chimes are incredibly faint - I can barely hear them but they are there.
Then, last week, after taking my dog for a rabies vaccine, she jumped against the door and the chimes started up loud and clear - and now it's back to the almost silence again.
It seems that a wire is loose but would that result in faint volume? Also, what would be the best guide on how to get access to the wiring to verify?
Thanks
oliver_cfc is offline
Old 03-25-2015, 10:56 AM
Probably going to be a bad speaker. The dog bumping it most likely made it "fix itself" temporarily.
Either way,wire or speaker, you're gonna have to pull the door panel to check it.
A 9 year old car, your best way is to just go ahead and replace the speaker while you're in there. And replace the other side as well.
firemangeorge is online now
Old 03-25-2015, 12:04 PM
LawDog88's Avatar
For the age, (mine is an 08 and lost 3 of 4). May just want to bite the bullet and replace all 4. Longevity and lack of time spent doing it again later!
LawDog88 is offline
Old 03-25-2015, 12:32 PM
yes all 4 use the search window for recommended speakers and size to get!
Careful popping the door panels off the inner door handles remain attached
Oldblue is offline
Old 03-25-2015, 02:25 PM
oliver_cfc's Avatar
Thanks all. Music-wise, the lack of the speaker doesn't bother me but I have locked the keys in a few times (key fob also broken) so the chimes would be nice.
Old 03-25-2015, 03:30 PM
Technical Moderator
If you search the site there is a how to remove the door panel.
donbrew is offline
Stryker
12-08-2018 02:58 PM
Bahta
04-29-2015 11:43 AM
Monty
03-25-2013 02:34 AM
HHR911
03-30-2012 11:11 PM
RICK167448
Maintenance and Upkeep
10-10-2011 02:10 PM
Quick Reply: front left speaker volume incredibly low
