Front Wheel bearing Inquiry
Old 05-29-2011, 03:05 AM
anasbio's Avatar
Hello Everybody
can I use front bearing with ABS on my HHR 2007 which is not equiped with ABS.
because the dealer have only front bearings with ABS
anasbio is offline
Old 05-29-2011, 10:17 AM
Zagohhr's Avatar
If it fits, you can use this. The main difference among them is that the ABS has a connector and sensor.
Zagohhr is offline
Old 05-29-2011, 01:41 PM
Technical Moderator
However, try Autozone,Pepboys, Advance and the Ebay. I have noticed that they are suddenly available from the auto box stores, probably cheaper than the StealerShip. I do know that the ones I got from Ebay where a lot cheaper than the dealer, and was Timken branded (if memory serves, about $190 each). I just checked Ebay, They have really come down in price! In fact Even though I don't need new ones yet, I bought 2 National brand for $36.20 shipped. That was too good a price, and I will need another set someday.
Of course thing may be different if the car is in Iraq.
donbrew is offline
Old 05-29-2011, 06:23 PM
interrex's Avatar
http://www.autozone.com/autozone/par...65268_0_0_6831 with out abs
interrex is offline
Old 05-29-2011, 10:35 PM
geg
geg's Avatar
Bearings do not differ from each other.
No incisions or electronics.
"ABS"and "Do not ABS" differ structure of the hub.
geg is offline
Old 05-29-2011, 10:58 PM
QuickRick's Avatar
Cheaper wheel bearings
When you say that the price is way down, so is the quality. If you can buy a Timkin bearing for a good price it is one thing, but don't think that the Chinese made one from Advance is the same as the dealer piece.
My buddy has had two cheap bearings in his S10 fail that were the junk brand; where's the saving when you have to redo it in 11 months like his?
QR
QuickRick is offline
Old 05-29-2011, 11:01 PM
oneton's Avatar
Non abs hubs are less $ to buy ! I just had to buy two!!
oneton is offline
Old 05-30-2011, 12:31 AM
AJochum's Avatar
Have you checked the warranty status? My '07 bought new has a 100,000 mile warranty on the drivetrain. I have had to have both front wheelbearings replaced by GM at n/c.
AJochum is offline
Old 05-30-2011, 05:20 AM
anasbio's Avatar
so can I use the one with ABS on my car which is without ABS?
because I don't want to open the car before getting sure that it could fit.
anasbio is offline
Old 05-30-2011, 05:07 PM
Technical Moderator
I don' know why you couldn't, same bolts, same splines, just have to cut the wire off. But the correct parts should be available to order.
donbrew is offline
Quick Reply: Front Wheel bearing Inquiry
