Turn right and the car wont go
Old 05-08-2009, 07:14 PM
twatts28's Avatar
Exclamation Turn right and the car wont go
I am having a problem with my HHR. When I am driving down the road and I turn to the right, the speedometer drops to 0 and its like the transmission goes into neutral. The motor revs up and the car still wont go. I have tried shifting into different gears but it does the same in all of them. I have taken it to the dealer and no one can figure out whats wrong. Has anyone else had this problem or i am the only lucky one.
twatts28 is offline
Old 05-08-2009, 09:37 PM
HHROwner's Avatar
Sounds electrical - maybe something in the column.....just guessing though
HHROwner is offline
Old 05-08-2009, 09:41 PM
lunchbox's Avatar
possibly check the battery to see if its secured down. my celica had a problem like that, the battery wasn't bolted down, and it kept grounding out on the hood when i would turn left. probly not the issue with yours, but the only thing similar to that problem i've had.
lunchbox is offline
Old 05-08-2009, 10:48 PM
IgottaWoody's Avatar
One more item..check trans fluid levels..on a hard turn its possible the fluid is shifting to one side and uncovering the pickup...thereby sucking air..
IgottaWoody is offline
Old 05-09-2009, 06:41 AM
09 Panel's Avatar
Doesn't explain the speedometer going to zero.
Should be electrical, something shorting or losing power to the TCM?
09 Panel is offline
Old 05-09-2009, 09:33 AM
kwboydston's Avatar
I thought I read a service sheet about wires rubbing a bare spot and causing elec. issues
kwboydston is offline
Old 05-11-2009, 07:44 AM
twatts28's Avatar
This may sound stupid, but how do I check the tranny fluid when there is no dipstick
twatts28 is offline
Old 05-11-2009, 08:01 AM
09 Panel's Avatar
You can't and it's not likely an issue since you say things like your speedometer drops to zero when it happens. Sure sounds like a wire harness rubbed through somewhere.
09 Panel is offline
Old 05-11-2009, 10:37 AM
shaginwgn's Avatar
might want to check the metal bracket near the right side of oil filler cap and see if the bracket rubbed through the engine harness. My 06 had a similar issue when I turned right the engine power was reduced, dealer had to work with the Gm tech line and figured out to rewire power steering module so now i have two wires running on the outside of my engine harness loom
shaginwgn is offline
Old 06-28-2009, 05:38 AM
twatts28's Avatar
Thanks
Thank you all for all the suggestions. I had checked all the wiring on the transmisson and couldn't find anything. But it was the one by the oil filler neck that had rubbed thru. What a stuiped design, lets run a wiring harness right up against a sharp metal bracket that should work just fine.
Thanks
twatts28 is offline
Quick Reply: Turn right and the car wont go
