gears
Old 03-31-2015, 08:46 PM
gbell73's Avatar
gears
Can someone explain to me why I can't shift into any gears?
gbell73 is offline
Old 03-31-2015, 09:33 PM
LawDog88's Avatar
Manual or Automatic?
LawDog88 is offline
Old 04-01-2015, 12:19 AM
Without more info about all that can be said is "cause something is broken". More info like lawdog states would really help in pinpointing the problem for you.
How many miles on the car?
Has the auto trans ever been serviced?
Does the auto shifter move if it's an automatic?
Does the shifter move if it's a manual?
Does the clutch petal go the floor and return if it's a manual?
Do you have clutch/brake fluid if it's a manual?
whopper is offline
Old 04-01-2015, 06:20 AM
Technical Moderator
I can! It's broken.
donbrew is offline
Old 04-01-2015, 07:14 AM
LawDog88's Avatar
Originally Posted by donbrew
I can! It's broken.
Good one Don.
LawDog88 is offline
Old 04-01-2015, 10:15 AM
I can! It's broken.
That was almost going to be my response - and I even actually checked to make sure April Fools day hadn't snuck up on me.
Come on people, we want to help - we really do - but you have to at least make an effort to supply some helpful information if you sincerely are looking for assistance.
whopper is offline
Old 04-01-2015, 10:27 AM
tireman1554's Avatar
Maybe your right arm is broken. I'd call 911.
tireman1554 is offline
Old 04-02-2015, 11:42 AM
Automatic there could be special warranty for that!
Standard could be the shifter linkage has bent or the rod guides are destroyed!
Oldblue is offline
Old 04-02-2015, 12:22 PM
gbell73 has not been back since making the original single post. Another 1-poster?
whopper is offline
Old 04-02-2015, 06:00 PM
Maybe he or she is out fixing the problem!
Oldblue is offline
Quick Reply: gears
