Bad Paint
Old 10-11-2010, 08:43 AM
drummerboy0088's Avatar
Bad Paint
I've owned my HHR for about a month now and the paint is starting to chip off the front of the hood. Also the rear door (driver side) is a lighter black than the rest of the car. When I wash the car and start to dry, that particular door ends up having a haze/streaks like a window would if you would try to clean it in direct sunlight. I wash my car either early in the morning or right before the sun sets in the shade BTW
I do know GM had bad primer on cars for a while, do you think that's the case with my HHR? it's a 2009 HHR 1LT Black/Black
drummerboy0088 is offline
Old 10-11-2010, 09:32 AM
GRUMPEE's Avatar
Chips on the hood - Could it be debris from the road kicked up by other cars?
Door paint difference - sounds like the door was previously repaired the repainted (albeit bad job).
Still the paint on HHRs and most cars made presently are not as tough - I think you can thank the EPA for that.
GRUMPEE is offline
Old 10-11-2010, 01:59 PM
we checked the carfax report and it showed it's an accident free car. As far as the chips I thought it was from the road also, but the chips are in too close of a pattern to look like it's from the road.
Old 10-11-2010, 02:19 PM
hyperv6's Avatar
It is simple. It is just crap tossed up from the road and todays modern paint.
Keep in mind todays pain like pointed out above is nailed by the EPA even at the factory. This is now a water based paint that is not as durable as the paint of old.
You add the todays water based paint with a HHR that has a lot of exposed painted surface area and you get chips.
If you tail gate or drive a HHR in a high debri area you are going to get chipped up pretty good. The only way to prevent it is the clear plastic bra from 3M.
Note paint is all the same on most cars today and chip are on the increase. Just the way it is in this so called Green Minded world.
hyperv6 is offline
Old 10-11-2010, 02:38 PM
HHorange's Avatar
Carfax is a good tool but it will not always tell you if a car has been worked on/wrecked.
Sure sounds like at least the door was a repaint.
HHorange is offline
Old 10-11-2010, 02:49 PM
urbexHHR's Avatar
Just because it doesn't have a carfax problem doesn't mean it was never worked on. My HHR you can tell the rear bumper was repainted (although it took me almost a year to notice)... It's got a clean carfax. If you don't report something to your insurance, and it doesn't involve a police report (backing into your house, or something else of yours on your property). Heck, my Grandpa had a '95 Caprice he bought new, and from day 1 you could tell the hood had been repainted...
urbexHHR is offline
Door paint could have been damaged with some kind of polish that was applied in direct sunlight, or just wrong for newer paints/clearcoat...... Not saying the OP did this, but at some point before he owned the car. You may want to get the opinion of a professional detailer, don't let him talk you into anything, just see what he thinks.
The chipping I'm going to agree is probably the normal chipping we are all seeing...... as far as the close pattern, maybe a previous owner tailgated a salt truck (hopefully that's a joke, but some people are not all that bright......)
Greybeard999 is offline
Old 10-11-2010, 03:58 PM
hyperv6's Avatar
I will have to third the carfax as it never tells all.
hyperv6 is offline
Old 10-11-2010, 04:00 PM
urbexHHR's Avatar
I remember a member here posted a link to a truck at a dealer that was his former truck...showed it had a clean carfax, and the dealer said so too. Then he posted the picture of the truck with all the dents from the accident that he was in with it...
urbexHHR is offline
bigjacksauto
03-21-2013 12:48 PM
pyro panel
11
07-21-2012 10:22 AM
TY&HHR
12-08-2008 01:13 PM
MikeX
06-20-2006 09:29 AM
Quick Reply: Bad Paint
