Radio problem - new to forum
Old 10-16-2009, 08:11 PM
macarchie's Avatar
Hello people... I purchased a '08 LT (white) a few days ago. I've been reading threads on the forum for a couple of weeks in anticipation of the purchase so I could learn what problems to look for - this forum has been very helpful. I'm new to the HHR but not new to GM.
I was playing with the stock MP3 radio earlier today; the owners manual says it will hold 18 preset stations, but I could not get it to switch to FM2 or FM3 (hence it would only hold 6 stations). This is not a major problem - just a nuisance. The CD works fine and I can switch from FM1 to AM and back with no problem. My next step is to shut off the power to the radio for a while and then reset it. Any body else have this problem or any ideas on what to check?
thanks in advance... Jimmy
macarchie is offline
Old 10-16-2009, 08:23 PM
ChevyMgr's Avatar
First you need to push the menu button and make sure you are set up for 6 favorites (FAV)
Then you need to press the FAV button and you should have 6 selections to scroll through. Then on each selection set up what station you want for each button.
ChevyMgr is offline
Old 10-17-2009, 09:56 AM
macarchie's Avatar
When I first checked it, the FAV was set to 2. I changed it to 6. Then it still wouldn't see FM2 or FM3. When I hit the BAND button - it would switch from FM1 to AM and back. When I tried to save one of the AM stations, it changed the FM1 setting.
I bought it at carmax and it appears to be in great shape. They have a 5-day no questions asked return policy - but I don't see this issue being major enough for that. My wife says they should fix it, but I don't want to put it in the shop for a few days and run the risk of messing up something else.
I can live with only 6 presets; besides I can play an MP3 CD with 140 songs or an Ipod.
thanks for the reply... Jimmy
Old 10-17-2009, 10:13 AM
ChevyMgr's Avatar
There is no FM1 and FM2. You have to push the FAV button to scroll through each set of 6 section. Just keep pushing the FAV button, you will see what I mean.
ChevyMgr is offline
Old 10-17-2009, 10:16 AM
You can set anything to your favs. So on our we have FM and xm mixed. So on FAV1 we have a couple local FM and a few xm. I think it's great the way they set this up.
GDZHHR is offline
Old 10-17-2009, 09:52 PM
macarchie's Avatar
Thanks guys... problem solved... I think I'm gonna like this car.
- Jimmy
Rikki Sixx
09-06-2015 12:56 PM
DPYC 79
03-04-2014 03:22 PM
wendykay
Maintenance and Upkeep
11-27-2013 07:29 AM
JeffR
02-02-2011 03:26 PM
blu ss
01-28-2011 12:19 PM
Quick Reply: Radio problem - new to forum
