Heat gauge and AC not working all of a sudden
I just bought 2007 HHR LS and having the same problems with temperature gauge and air conditioner. I already replaced the coolant sensor, didn't work, so today I am having the thermostat replaced. Is this the same as mentioned in the above posts?
#26
Same thing happened to my wife, I found the relay in slot 15 in the fuse box under the hood was the problem, switched it with 18 to test and as soon as I plugged it in I heard the
AC motor kick on, quick trip to the auto store when its open and it will be good as new.
#27
The same thing happened to me this weekend. On Friday morning, the A/C quit working all of a sudden. Half way home on Friday afternoon, it came back on as magical as it quit. It worked fine all weekend, but just a little while ago, it quit again, but this time I noticed that my temp gauge is not working at all and my digital readout is dashes. I was thinking that it may be the temp sender, but someone I read changed it without being the problem, I will try the relay as JTP suggested. thank you.If for some reason the relay does not do the trick, does anyone know where the temp sensor is located? I would appreciate it. Thanks.
rad1steve
09-11-2014 05:10 PM
