Heater Blower/Fan
Old 04-09-2012, 03:31 PM
mn64falcon's Avatar
Unhappy Heater Blower/Fan
My heater will not blow air anymore. I have checked all the fuses and they appear to be okay. When i turn the fan switch, nothing happens. It worked one day and the next it didn't. What should i look for now?
mn64falcon is offline
Old 04-09-2012, 04:09 PM
SpaceCowboy's Avatar
test the blower fan itself use a volt meter and see if it is getting power
SpaceCowboy is offline
Old 04-09-2012, 06:21 PM
db/sb's Avatar
Also check the blower resistor. Ours would only work on the high setting after getting wet from the infamous cowl leak. They solved the problem by replacing the resistor.
db/sb is offline
Old 04-13-2012, 09:19 AM
panelmoxie's Avatar
mine also crapped out after the infamous cowl leak, they replaced the blower fan under warranty, been good now for 150,000 miles
panelmoxie is offline
shepards2012
03-10-2014 08:17 AM
volusiacrazy
06-11-2013 12:54 PM
Dinky Toy
02-16-2013 12:27 PM
judy1bob
Maintenance and Upkeep
01-19-2013 04:13 PM
purple haze
04-11-2010 09:06 PM
Quick Reply: Heater Blower/Fan
