Help!!! I need more info ENGINE AND TC LIGHT ON
Old 11-27-2012, 09:24 PM
mzsusyQ's Avatar
Unhappy Help!!! I need more info ENGINE AND TC LIGHT ON
I have a 06 Chevy HHR and recently the engine light and tc light came on ... They pulled code P0014, I've read on here it's either the camshaft solenoid or sensor ... I also read to clean it and/or replace it/them ... How do I know the difference and most importantly will by baby (car) mess up if I continue to drive it this way!!!??? Someone? Anyone? Help?
mzsusyQ is offline
Old 11-28-2012, 03:14 PM
@mzsusyQ, I can understand how frustrating this can be trying to take care of this on your own. If you don’t get the information you’re seeking on here, I recommend getting the input of your local Chevrolet dealership’s service department.
Happy Holidays!
ChevroletCustomerService is offline
Old 11-28-2012, 09:48 PM
mzsusyQ's Avatar
Thanks Michelle, I've actually found some helpful info and a few good threads on here!! Happy Holidays to you and yours!
mzsusyQ is offline
Old 11-29-2012, 12:18 AM
mzsusyQ- Is the CEL (aka: check engine light) Flashing or on steady ?
Does it still run good ?
P0014 is Exhaust cam CMP, performance problem
sleeper is offline
Old 11-29-2012, 12:43 AM
Easy job for the fix: https://www.chevyhhr.net/forums/how-tutorial-library-21/camshaft-position-actuator-solenoid-valve-replacement-w-pics-p0010-11-p0013-14-a-28779/ - 45 minutes or less for the whole job.
Your code P0014, points to the EXHAUST solenoid (not sensor) - GM part number: 12655421 - cost should be ~$50-70
And best to do it fairly soon, as the hard shifting of the transmission can't do it much good.
whopper is offline
Old 11-29-2012, 02:37 PM
mzsusyQ's Avatar
Sleeper - its steady, well sometimes both lights turn off for a while but for the more part they're always on besides that it runs very good!! This is the only problem, I'm good at keeping up maintenance and wear and tear :)
Whopper - your link is actually the one we found after I posted this and has been very helpful in understanding the problem!! Thanks so much ... I'm going to have them changed next week (fingers crossed) and will keep my thread updated :)
mzsusyQ is offline
Old 11-29-2012, 05:55 PM
Technical Moderator
Doesn't the "solenoid" only apply to 2.4L, or, is it year specific? My 2008 2.2L (also my 2011 2.2L) only had a cam position "sensor", and that's on the intake side. The OP does not say which engine.
donbrew is offline
Old 12-06-2012, 10:34 AM
mzsusyQ's Avatar
Ok guys ... I'm about to order the part but now I'm confused (again) sorry ... I'm curious to know the answer to donbrews question :/
mzsusyQ is offline
Old 12-06-2012, 01:47 PM
Well. As donbrew says, we don't know which engine you have. 2.2 or 2.4?
firemangeorge is online now
Old 12-06-2012, 02:38 PM
mzsusyQ's Avatar
Sorry lol it's a 2.4 :)
mzsusyQ is offline
Quick Reply: Help!!! I need more info ENGINE AND TC LIGHT ON
