Help!!! I need more info ENGINE AND TC LIGHT ON
The lower two quotes are in my signature. I meant these two:
Same post; two different threads. (I just posted it to the wrong thread)
Hello sdavis1465,
I understand that you are unhappy with the service you experienced at your local dealership. I do apologize that you are unhappy and for any inconvenience this may have caused you. Feel free to contact us for further assistance.
Jennifer T.
Chevrolet Customer Care
Jennifer T.
Hello sdavis1465,
Jennifer T.
Jennifer T.
I'm back!!!
Hey everyone!! I'm back with the same problem except the code that's pulling now is a p010 I need ya'lls expertise again!! I believe it's been about 2 years if I'm not mistaken since first time I posted about my problem so the fix lasted a bit just need to figure out how to fix this code now!! Any and all info welcomed and appreciated!! <3
Do you mean a P0010 code?
If that's the case, give the following thread a read....
https://www.chevyhhr.net/forums/how-...13-14-a-28779/
You'll note that we've looped right back to whopper's reply in post #5 from 2012.
#26
#27
If it's the p0010 code, you only need the one solenoid - the one for the INTAKE side - you do not need to replace them in pairs, although you may wish to consider doing so rather than face the possibility of tearing apart to replace the other one if it too goes faulty or gets fouled with overdue oil changes etc..
And IMO I'd stick with the genuine GM ones. The part number (GM # 12655420)is at the start of the highlighted thread above: https://www.chevyhhr.net/forums/how-...13-14-a-28779/
