HHR 2006: Unlocking driver's side door with key sets off alarm - Chevy HHR Network
Reply
Thread Tools Search this Thread
Old 11-04-2011, 02:10 PM   #1
Unhappy HHR 2006: Unlocking driver's side door with key sets off alarm
Hi everyone,
Ever since the battery container broke off of the PCB on my keyfob, I've been left with using the key to unlock my car.
For locking the car, I have to step out, press the lock button on the driver's door, then close it. After a few seconds, the doors will lock. Getting back in the car is the interesting part, though. After unlocking and opening the driver's side door with my key, the alarm will go off, with a short honk occurring about every half a second. (Somehow, one day when I unlocked the car, the horn started honking at longer intervals (like a panick-panick-alarm), not sure how I did that). After I put the key in the ignition and turn it to the "on" position, the alarm will go off, and I can proceed with unlocking the rest of the car if passengers need to get it.
I recall reading a thread with an issue similar to this, although I don't understand how this security measure is really necessary (seems to be more of an inconvenience and embarrassment than secure). Don't you need an exact replica of the key to be able to unlock the driver's side door in the first place? If not, how does putting it in the ignition confirm that the key is legitimate?
Also, another thing that I find rather odd is that if I step out and lock the driver's side door with the key, it will only lock that door, and not the rest of the car. It doesn't seem to support turning it twice to lock the rest of the car, either. I can't image the point of only locking the driver's side door when the rest of the car is still unlocked
If anyone has any suggestions (other than buying a new keyfob, I intend on asking someone to help me solder the battery container back on) for locking/unlocking my car without setting the alarm off in the meantime, I would greatly appreciate your input.
Thanks!
tgp1994 is offline   Reply With Quote
Old 11-04-2011, 03:11 PM   #2
Images: 128
to the forum tgp1994!
Here's a trick to try, lock the door with the key not the power lock button, then open the door with the key....the horn should stay blissfully quiet.
If it doesn't work the first time, unlock all the doors, then lock each door manually and then lock the driver's door with the key. Then try unlocking the driver's door with the key, the horn should remain silent.
843de is offline   Reply With Quote
Old 11-04-2011, 03:15 PM   #3
Images: 8
When I bought my HHR last month, the fob had the same battery connection issue and when I tried the key in the door my alarm went off as well. I even found a thread about this either on here or another forum, I don't rememeber which one. That just seems to be the design on these cars and unforetuneately you just have to live with it I think. I have a soldering gun so I just fixed my fob and all has been well since.
Like you found, I believe the people in that thread said locking it via the key in the drivers door was the only way to lock the car without arming/setting the alarm. Then when you use the key to unlock it the alarm is not active and will not sound off.
07azhhr is offline   Reply With Quote
Old 11-04-2011, 03:59 PM   #4
Thanks! :)
Interesting idea about manually locking the doors. I think I'll give that a try. The issue I found with only locking the driver's side door with the key is that, it only locks the driver's side door :P
To the soldering gun I shall go! At least until I try 843de's suggestion, although I think I'll want my fob working anyways.
Old 11-04-2011, 06:27 PM   #5
I already had to re-solder the battery connections in both of our fobs. It wasn't hard to do.
voigtsga is offline   Reply With Quote
Old 11-04-2011, 06:35 PM   #6
Senior Moderator
Images: 99
Here's a link to a description of how to resolder the broken battery contacts - hope it helps: http://chevyhhr.net/forums/showthread.php?t=22641
whopper is offline   Reply With Quote
Old 11-04-2011, 06:51 PM   #7
Awesome guys, thank you :)
Old 11-08-2011, 10:25 AM   #8
@tgp1994, how did things go with using the key to lock and unlock your doors on your HHR? Were you able to get your soldering job done for your fob?
ChevroletCustomerService is offline   Reply With Quote
Old 11-08-2011, 02:44 PM   #9
Unfortunately, the method of locking the doors with the power lock, unlocking the driver's door manually, then, stepping out and locking it with the key did not seem work, the alarm still went off. I haven't been able to solder my keyfob yet, I'm going to try to arrange with a friend to get that done next week.
Thanks for checking in!
Old 11-09-2011, 11:31 AM   #10
@tgp1994, I apologize that the suggestion that you tried didn't work. I am glad that friend can solder this for you.
Don't hesitate to get a hold of me in the future.
Reply
Thread Thread Starter Forum Replies Last Post
driver side rear door leaking troyacantrell Problems/Service/Repairs 2 12-18-2012 11:43 PM
2006 Driver Side sun visor flops down!! red73mustang Maintenance and Upkeep 9 10-16-2012 12:58 PM
Interior driver side door handle pastormarie Problems/Service/Repairs 6 10-08-2012 11:47 PM
how do I remove the driver side door mirror? HokieHHR Mods - Exterior 4 02-26-2011 03:47 PM
Tags
hhr2006 alarm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 2005 - 2013 Internet Brands, Inc. All rights reserved.
