HHR 2006: Unlocking driver's side door with key sets off alarm
Unfortunately, the method of locking the doors with the power lock, unlocking the driver's door manually, then, stepping out and locking it with the key did not seem work, the alarm still went off. I haven't been able to solder my keyfob yet, I'm going to try to arrange with a friend to get that done next week.
Thanks for checking in!
Once the key is out of the ignition and you use the power lock switch inside the car then you are activating the alarm system. Since it has a 30 sec or so delay you have enough time to unlock the door, get out and shut the door without setting the alarm off.
Try setting your door locks in the DIC to drivers only when turning off the car. This will allow you to already have all the other locks locked when you shut the car off. Then all you have to do is get out, shut your door, and lock it with the key.
I think that'll be the final solution.
It is what I did on mine on my 3rd day of ownership. Hasn't failed since...only been 1.5 months lol.
Just wanted to let everyone know,
I just finished soldering the battery holder onto the keyfob. It's amazing how solder can go from a solid, to liquid, then back to something stronger than most glues! I think the range is even improved, too...
Thanks again, everyone.
Michelle, again don't take this the wrong way, but tell CHEVY we want someone who is authorized to help, not someone with a box of band-aids, when we need stiches.
Now to answer the OP's question....... Since Chevy can't.
Unlock all doors, then lock the driver's side door manually with the key. This tells the security system that the key itself is in control. This happened to me several times a few years ago, when the FOBs went bad.....annoying!
you can also check the DIC, and change the security setting that way.... the procedures are listed in the manual under DIC control,security
Thanks foolmoon,
What seemed to work for me was locking all of the doors with the power lock, pulling up the driver's lock, then getting out and locking the door with my key. I'm not sure if that's pretty much what you just said, but thank you for the suggestion. I'm just glad my fob is working again.
Here's a link to a description of how to resolder the broken battery contacts - hope it helps: https://www.chevyhhr.net/forums/how-tutorial-library-21/keyfob-cold-solder-repair-22641/
I've had my Avalanche 10 years and the key fobs both work fine still - never even replaced the batteries.
Thanks foolmoon,
If you set your unlock setting in the DIC to driver I think it is, the car will auto unlock ONLY the drivers door upon removing the key from the ignition. Then you just get out and lock the drivers door with the key. It is that simple to prevent the alarm from going off when using the key.
