HHR 2006: Unlocking driver's side door with key sets off alarm
Old 01-02-2012, 07:19 PM
63falcondriver's Avatar
My battery connection broke in my fob and I soldered it back together. I thought it was an anomaly but it appears it is a weakness in the design. I also had the alarm activate when unlocking with the key. Hate that!
63falcondriver is offline
Old 01-10-2012, 08:30 AM
Blue_SS's Avatar
Bumping this because I thought I had a bad fob, but it appears it's something else. The fob has been flaky lately - sometimes working and sometimes not.
Well, I discovered that when it won't work, the key works fine in the door, without any alarm! So I think the security module (or some such thing) is erratic. When the alarm is actually on, the fob works fine. Any ideas on what to do next?
Blue_SS is offline
Old 02-13-2014, 03:57 PM
Stevethefolkie's Avatar
Originally Posted by 07azhhr
Try setting your door locks in the DIC to drivers only when turning off the car. This will allow you to already have all the other locks locked when you shut the car off. Then all you have to do is get out, shut your door, and lock it with the key.
Brilliant - now I can lock my car at work and not have to carry around the key fob in addition to the key. It was on page 3-45 of my owners manual - suppose I should have read it some time ago!
Thanks
Steve
Stevethefolkie is offline
Old 09-29-2014, 01:43 PM
senfield's Avatar
Originally Posted by 843de
to the forum tgp1994!
Here's a trick to try, lock the door with the key not the power lock button, then open the door with the key....the horn should stay blissfully quiet.
If it doesn't work the first time, unlock all the doors, then lock each door manually and then lock the driver's door with the key. Then try unlocking the driver's door with the key, the horn should remain silent.
This is great as long as no one tries to enter the vehicle through the back hatch which doesn't lock manually.
Last edited by senfield; 09-29-2014 at 01:57 PM. Reason: Found my mistake when reading another post
senfield is offline
Old 10-01-2014, 12:47 PM
db/sb's Avatar
Yes it does. You grab the handle and push it closed....that would be manual wouldn't it??
db/sb is offline
Old 10-01-2014, 01:09 PM
  #26
User 11223's Avatar
Isn't he talking about how the back hatch uses a sort of push button which then opens the latch keeping it closed? I guess I never thought of how the car decides whether or not it should open the hatch... Perhaps if the passenger doors are locked?
User 11223 is offline
Old 10-01-2014, 02:21 PM
  #27
db/sb's Avatar
He said "the back hatch which doesn't lock manually" after awakening this over 7 month old thread to add that bit of superfluous/incomplete/misleading information. He didn't say unlock which can only be done with the remote unless you consider the emergency release.
db/sb is offline
troyacantrell
12-18-2012 11:43 PM
red73mustang
Maintenance and Upkeep
10-16-2012 12:58 PM
pastormarie
10-08-2012 11:47 PM
HokieHHR
Mods - Exterior
02-26-2011 03:47 PM
Quick Reply: HHR 2006: Unlocking driver's side door with key sets off alarm
