HHR Key stuck in the ignition
Old 01-08-2014, 02:40 PM
dande54's Avatar
I have a 2006 HHR and the key is stuck in the ignition. From what I read on other threads it is the shifter linkage. I have found some on E-bay to replace it and I was just wondering if one from a 2011 will fit it?
Thanks,
Don
dande54 is offline
Old 01-08-2014, 03:21 PM
cj krause's Avatar
recall on this
this is how you get the key out
this usually is the problem and fix
http://www.yesteryeardepot.com/SP2921.JPG
cj krause is offline
Old 01-08-2014, 04:29 PM
Madmatt6988's Avatar
I had the same problem. Button under the steering column wouldnt release the key. They replaced the ignition under warranty. No problems since.
Madmatt6988 is offline
Old 01-08-2014, 06:39 PM
I think the 06's are excluded from this "recall".
Someone can correct me if I'm wrong.
firemangeorge is offline
Old 01-08-2014, 06:55 PM
to the forum Don!
It wasn't a recall exactly, but a Customer Satisfaction Campaign on GM's part. I believe that the '06 model year HHRs were excluded, but GM seems to still be handling this on a case by case basis for non-covered vehicles.
Talk to your dealer's Service Manager about a "Goodwill" repair.
Here's the thread on the Campaign letter....
https://www.chevyhhr.net/forums/problems-service-repairs-42/letter-gm-ignition-lock-cylinder-41009/
843de is offline
Old 01-09-2014, 08:02 AM
Technical Moderator
People seem to say a 2011 shifter with the boot will fit.
donbrew is offline
Old 01-09-2014, 02:36 PM
dande54's Avatar
Thanks, I have found out it is the shifter. I took it apart last night and the pin had slid out. I put it back in until I can get one ordered and it is working fine for now. Looks like a pretty easy fix.
dande54 is offline
Old 01-09-2014, 04:53 PM
Technical Moderator
If I remember correctly there is a TSB on the 2006 model, with pics. Maybe it was just another thread, try the SEARCH. I am pretty sure that somewhere on here I've seen reference to a design change after 2006, and I know I've seen pics.
donbrew is offline
Old 01-09-2014, 06:50 PM
the_shmoo's Avatar
Try these posts on shifter removal and repair.
https://www.chevyhhr.net/forums/problems-service-repairs-42/auto-shifter-removal-43855/
https://www.chevyhhr.net/forums/show...hlight=shifter
the_shmoo is offline
Old 01-09-2014, 07:01 PM
Thanks shmoo.
Those threads we're eluding me.
843de is offline
Quick Reply: HHR Key stuck in the ignition
