Humming Noise
Old 06-25-2015, 08:30 AM
QbanBuc's Avatar
Humming Noise
Hi everyone. New to the forum. I have been looking around for answers but it seems as if the issues of others doesn't fully match those of mine.
The humming noise I am experiencing appeared as I was on the highway this morning from the front end of the car. It was rather low in volume but got louder as my drive continued. I parked the car in my job's parking garage and the humming was still there after I parked. Odd thing, when I pulled in though, it went away for a brief moment then returned. Any ideas of what could be going would be great. I may not be able to take it anywhere until Tuesday.
It's a 2006 HHR. Thanks in advance.
QbanBuc is offline
Old 06-25-2015, 09:37 AM
Technical Moderator
If only when moving; hub.
If also while not moving; flex pipe.
donbrew is offline
Old 06-25-2015, 09:40 AM
Technical Moderator
But it could be a plastic bag stuck under the car or a Dr. Pepper cap stuck in the alternator.
donbrew is offline
Old 06-25-2015, 09:55 AM
QbanBuc's Avatar
Excuse my ignorance but it appears the bag or cap could be easily fixed, right?
But yes it's doing it while I am not moving as well. I put it in park and it was still there. I'm hoping I can still drive it just fine until Tuesday.
QbanBuc is offline
Old 06-25-2015, 01:49 PM
Technical Moderator
I added those possibilities because members have led wild goose chases and those ended up being the solution.
You probably have a cracked flex pipe. Type "flex pipe" into the SEARCH box at the top of every forum page for information.
donbrew is offline
Old 06-25-2015, 02:46 PM
QbanBuc's Avatar
Odd thing is though I just checked to see where that sound is coming from as I called a local mechanic. I pinpointed the humming sound to the passenger side of the engine where the alternator and belt is. So I guess it's something there in that area. Also noticed a smell similar to electrical wires burning or something along those lines.
Still in a bind because of course they give you the "come in and we'll check it out" line but they are closed when I begin and end my shift. So still looking to shoot for Tuesday if it makes it that far.
I will look through the flex pipe threads. See if there is anything similar to my issue.
QbanBuc is offline
Old 06-25-2015, 07:11 PM
Have you checked the belt itself for cracks, chunks missing etc.?
whopper is offline
Old 06-25-2015, 08:51 PM
QbanBuc's Avatar
Indeed it does. I actually ran it for about a half hour and the red battery (charge system?) light turned on for about five seconds the first time then a few minutes later turned on again but was literally a second or two and never turned back on. However buzzing/humming remained.
To be specific I noticed cracks.
QbanBuc is offline
Old 06-25-2015, 10:29 PM
Then don't you think you might have found the problem?
ie: the belt or the tensioner.
whopper is offline
Old 06-25-2015, 10:47 PM
QbanBuc's Avatar
Not sure to be honest. I've tried looking at YouTube videos and the sounds I hear are nowhere near what I have found online. Plus, why would the belt give off my battery warning indicator?
I'm sorry for my stupidity, but that's why I came here, for some assistance or merely for someone to steer me in the right direction. I'm just not understanding how cracks in the belt would trigger that light. I would have assumed it was the alternator. (Apologies If I'm coming across a certain way. Just frustrated with the situation. I'm a journalist, not a mechanic lol.)
QbanBuc is offline
Quick Reply: Humming Noise
