Ignition Cylinder Lock? - Chevy HHR Network
Reply
Thread Tools Search this Thread
Old 01-13-2009, 11:05 AM   #1
Has anyone ever changed one?? How much involved??
richie6 is offline   Reply With Quote
Old 01-13-2009, 11:17 AM   #2
ChevyMgr's Avatar
Images: 707
2008 Chevrolet HHR | HHR (VIN A) Service Manual | Document ID: 1737997
Ignition Lock Cylinder Replacement
Removal Procedure
Disconnect the negative battery cable. Refer to Battery Negative Cable Disconnection and Connection .
Disable the SIR system. Refer to SIR Disabling and Enabling .
Remove the steering column trim covers. Refer to Steering Column Trim Covers Replacement .
Turn the ignition lock cylinder to the RUN position.
Important: There are two retainers on the ignition lock cylinder. Depress both retainers to remove the lock cylinder from the housing.
Depress the first retainer through the lock housing access hole (2) with a small allen wrench or similar pick-type tool. The lock cylinder will back out slightly.
Depress the second retainer through the lock housing access hole (1). The lock cylinder will back out slightly again.
Pull the lock cylinder out enough to locate the second retainer to the lock housing access hole (2).
Depress the retainer though the access hole (2) a second time. The ignition cylinder should release from the housing. If not, the ignition cylinder may need to be moved in and out several times to locate the retainer correctly in the hole.
Remove the lock cylinder from the lock housing.
Installation Procedure
Important: If you are installing a new lock cylinder, refer to Key and Lock Cylinder Coding .
Position the lock cylinder in the run position. Insert the cylinder into the lock housing.
Rotate the lock cylinder in the housing. Verify proper rotation.
Install the steering column trim covers. Refer to Steering Column Trim Covers Replacement .
Enable the SIR system. Refer to SIR Disabling and Enabling .
Connect the negative battery cable. Refer to Battery Negative Cable Disconnection and Connection .
2009 General Motors Corporation. All rights reserved.
ChevyMgr is offline   Reply With Quote
Old 01-13-2009, 11:24 AM   #3
Thanx a bunch..
Old 01-13-2009, 11:34 AM   #4
ChevyMgr's Avatar
Images: 707
You're welcome.
Reply
Thread Thread Starter Forum Replies Last Post
My Ignition Lock Cylinder battle HeavenlyHellRaiser Problems/Service/Repairs 3 03-05-2016 04:58 PM
Letter from GM for ignition lock cylinder metalhead52 Problems/Service/Repairs 183 03-23-2014 07:06 PM
DIY ignition cylinder lock replacement? sbrice54 Problems/Service/Repairs 6 08-21-2013 10:31 AM
2009 & 2010 Models with Ignition Lock Cylinder Issue!!! ChevyMgr Problems/Service/Repairs 10 06-04-2012 01:42 PM
Defective Ignition Lock Cylinder johngpeg Problems/Service/Repairs 10 07-29-2011 04:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 2005 - 2013 Internet Brands, Inc. All rights reserved.
