ignition key stuck
ignition key stuck
Has anyone experienced the ignition cylinder not turning completely to the off position? I am not able to get the key out without jerking and wiggling around on the gear shift . It will finally turn to the position to allow the key to come out, but sometimes takes forever. Would this be a sensor or something like that, not getting the message that the Transmission is in the Park position?
fixed under warranty
I took my 06 HHR in to the dealer today and they did the repair under warranty. It was a control unit under the gear shift column. A $ 370.00 part and 1.5 hrs labour.
