Intermittent vibration 50-55 MPH
Technical Moderator
I thought my sledge hammer repaired bent rim was causing a vibration between 50-55 that came and went.
It is now gone since I replaced all 4 injectors to cure my P0420. I guess I actually had a "too rich" misfire at a particular RPM caused by a leaky injector.
That's interesting.
I have never heard of an injector giving a vibration symptom.
Not bad you cured two problems with one repair. You got to like that.
One thing I have learned over the years is that The text book is not always accurate I the real world.
Car can do some strange this at times.
1993s10guy
7
04-23-2015 07:26 AM
