Key Fob 2008 HHR SS
Key Fob 2008 HHR SS
The "UNLOCK" button on my key FOB quit working. All the other buttons work. The problem is, I have to unlock the car with the key which makes the alarm sound off. Once I put the key in the ignition, the alarm stops. Is there a way to turn the alarm off, or to make the "UNLOCK" button work. I don't want to spend the money that Chevy wants to fix it.
Here's a handy thread on repairing the key fob contacts if cleaning doesn't do the trick.
https://www.chevyhhr.net/forums/how-tutorial-library-21/repair-key-fob-remotes-worn-out-contacts-30813/
Key FOB
Thanks for the link. I had already soldered the battery clips and cleaned the buttons and was trying to figure out a way to replace the buttons. Now I know. I will be buying a cheap calculator on the way home this evening. I'll let ya'll know how it works out.
I've been meaning to get back to this. I found an old calculator and cut the carbon pads off of the square root button. Nobody uses that button anyway. It is a tedious job, but it works like a champ.
Thanks for all of the suggestions.
I bought a keypad replacement for about 12 bucks on ebay. no need to repair, augment, modify.
http://cgi.ebay.com/ebaymotors/GM-KE...item3a6965ce2e
