Keyless entry
Old 12-26-2009, 12:23 PM
Silver bullet's Avatar
Keyless entry
I searched but didn't find exactly the issue I'm having. My keyless entry is having an intermittent problem, I push the unlock or lock & sometimes get nothing. Other times it works fine and I'm not getting any message on the dash about low battery in my fob or anything. Dealer said that 9 times out of ten, it's not the fob, of course it worked just fine when I stopped at the dealership. Any suggestions or similar problems? Thanks everyone in advance.
Silver bullet is offline
Old 12-26-2009, 02:59 PM
J W Davis's Avatar
Key FOB.....
Cold ,craked joint on cuircit board. See early post on same.
J W Davis is offline
Old 12-26-2009, 03:03 PM
Thanks, got a link?
Old 12-26-2009, 03:15 PM
Technical Moderator
Originally Posted by Silver bullet
Thanks, got a link?
It's the first sticky in the HOW-TO section
Don
donbrew is offline
Old 12-26-2009, 03:24 PM
rubics_cube's Avatar
Don
I'm not finding a link to the how section?! Seems like that would be a key link on most pages.
rubics_cube is offline
Old 12-26-2009, 03:50 PM
Technical Moderator
General Discussion > How To Guide. Sorry I Am bad at links. You are in General Discussion > Problems/Service Issues.
donbrew is offline
Old 12-26-2009, 04:02 PM
Ah, here it is- https://www.chevyhhr.net/forums/how-tutorial-library-21/keyfob-cold-solder-repair-22641/
Thanks much. Next question, if I pull out the battery, I don't have to reprogram or anything do I?
Old 12-26-2009, 04:13 PM
Technical Moderator
I don't know about 2009, I'd be more worried about the radio. The fob is matched to the BCM, so I think backup memory/power would keep the programming. I am over my head here. I believe that one of those 9-volt battery adapters that plug into the cig lighter would make the Question moot.
donbrew is offline
Old 12-27-2009, 01:27 PM
Sno White's Avatar
Ah, here it is- https://www.chevyhhr.net/forums/showthread.php?t=22641
I think Silver was taking about removing the battery in the FOB, not the vehicle's battery. If so no problem. Some of the older vehicles have had a problem with the remote receiver module in the vehicle or BCM loosing programming with total power loss in the vehicle.
Sno White is offline
Old 12-27-2009, 04:45 PM
Yes, that's what I meant. I have an '08, I wasn't sure. Thanks!
Quick Reply: Keyless entry
