Keyless entry
OK, one track mind, however, heed the warnings about the removal/installation of a battery. You can easily cause the solder problem yourself. You must remove the PCBoard from the rubber gasket and then gently push the battery in/out, being VERY careful not to lift the "cage" at all.
I had and issue with mine too. I was having a problem with removing my key with the shifter in park and bypassed the microswitch at the shifter and amazingly my remote started working again. I'm thinking the switch is a dpst switch and the contact was intermittent for that side of the switch. Its been working every since. Just a thought...hope it helps.
