Front headlight...bulb replaced or fuse issue?
My front headlight is out on my drivers side, so I thought; however, it dawned on me that my headlight comes on when I disarm my alarm, but doesn't work when I turn my car on. Don't know if I need to have the light replaced or is it a fuse issue.
Anyone had this issue? Really don't want to pay the labor cost at dealership.
Thanks.
Thanks.
Probably one of the two elements is burned out in the bulb.The alarm system flashes the high beams I think.Go out and try your lights:low beam/high beams.Most likely you have a low beam out.
AND, Welcome to the forum.
