Knocking, clicking under engine
Old 05-06-2014, 09:11 AM
grannydeb's Avatar
I have a 2007 HHR 2.4L engine and all of a sudden underneath the engine I started hearing a ticking or knocking sound it sounds as if it is on the left side. I came home and have not driven it since my brother who has worked on cars for over 30 years remove the head gasket but nothing was loose what would be the next step to finding out where the ticking/knocking coming from?
grannydeb is offline
Old 05-06-2014, 09:25 AM
db/sb's Avatar
I really doubt that he removed the head gasket....you must be using the wrong term in describing what he removed.
db/sb is offline
Old 05-06-2014, 09:29 AM
I would say to just let your brother try an figure it out since he has the car right there and can do some "hands on" diagnostics.
Trying to get a guess from us internet folks would be just that, a guess, since we don't have the car right here to look like your brother does.
No offense, but I also get the feeling from your post description that you're not that mechanically inclined with cars.
If he removed the head gasket that is a major job which is the removal of the top of the engine or cylinder head.
I'll guess here and bet maybe he just removed the valve cover to take a look.
Anyhow. Without a little better detail and info, it would be futile for us to even venture a guess.
Let us know if your brother comes up with anything. And, if he needs some advise, he could talk with us on this forum. Just let him use your username and this thread so we know who it is.
firemangeorge is offline
Old 05-06-2014, 08:05 PM
Technical Moderator
Moved to a more appropriate forum section. Not exactly a "2.4L Performance" topic.
By left side, do you mean the driver side? By underneath the engine, do you mean the bottom of the engine or underneath the hood?
donbrew is online now
Old 05-06-2014, 08:10 PM
some thoughts for him to look for, air cleaner box bracket, flex pipe, (this would be accompanied with a loud exhaust noise), timing chain tensioner, let us know what he finds!!!!
Oldblue is offline
Old 05-07-2014, 01:38 PM
Grizzly old man's Avatar
I wonder if the noise might be on the passengers side of the engine. When the serpentine belt went bad on mine it made a ticking noise when the engine was running. With the engine shut off I could not see the strip of belt that had torn lose from the rest of the belt.
With the engine running I could not see it because it was to fast. finally when I shut the engine off one time the loose bit was on top and easy to see.
The new belt was cheap and I had just bought the dandy {but mostly useless} serpentine belt tensioner adjusting tool from Harbor Freight. I ended up using a little ton and a half hydraulic bottle jack and a short length of 2x4 to move the belt tensioner.
Grizzly old man is offline
Old 05-08-2014, 06:33 AM
Technical Moderator
If the OP ever comes back, maybe we will find out exactly what they mean.
Old 05-08-2014, 07:35 AM
She has been back according to her stats. Just didn't bother to rejoin her own thread.
SwaintaN
03-25-2014 12:16 PM
Mischevious
10-10-2012 02:37 PM
ginginee
02-03-2010 09:42 PM
HPVOHHR
04-28-2008 06:31 PM
ian
01-19-2007 10:12 PM
Quick Reply: Knocking, clicking under engine
