Knocking noise in PS door over bumps
This started a couple weeks ago. Of course when I'm sitting in the pass. seat it doesn't happen. It's not the seatbelt adjuster in the B-pillar either. it is definitely comming from the door itself, and doesn't matter if the window is up or down. Anyone with this before?
Bet a bolt is loose that hold the window track or motor. My old '99 Silverado got a knocking noise of some sort with in a few months of being new and when I took off the door panel I found a bolt was loose and that was the problem. Later the other door developed the noise and again a bolt was loose.
Strange thought that your doesn't do it when you are in the pass. seat? maybe someone should be in the drivers seat and driving also
emorris
08-21-2013 08:58 AM
chocolatefonz
07-19-2010 12:26 PM
thirdgenz28
11-23-2007 08:08 AM
HHR321
02-17-2007 11:18 AM
