Low beam headlights won't come on
I have developed the same problem with my 2007 HHR. All lights work except low beams. The passenger side came back on briefly but is now out too. I hope the simple(?) bulb change works for me too.
Welcome Packmate , says you joined on 5/10 this is your first post, that has to be a record lurk
@Packmate, let me know how things go with you changing you bulbs.
Replaced headlights
Thanks, guys. Had the exact same thing with my 2011. Have never seen both headlights go out within a 24 hr period. Ever. Figured something more serious was the cause. Had already bought 2 new lamps, so I put them in and "shazam" they both worked. I guess I got a break as it's 21 degrees here right now with 4" of snow on the ground.
#26
Hhr low beams do not work 2006
i have the same problem and suspect it is not the light bulbs. It must be a device, fuse ,switch or relay before current reaches the light bulb.. I checked the fuse 64 and 65 and they are ok... But is there one before the actual high low beam switch.. Or maybe the auto light on off switch or if there is a fuse for that one.. (and where would that one be ?)
#27
OK. Since you didn't bother to post what year your HHR is, I'll give you an answer based on a 2010 owners manual. The fuse locations are pretty much the same 06-11.
Fuse #65---Dr. side low beam
Fuse #66---Pass. side low beam
Relay #71---Headlamp low beam
Fwiw. You posted that you checked #64. I show that to be the fuse to the cannister in the emissions system.
Saying you don't suspect it's the bulbs? Not sure what you're baseing that on but there have been many here that found out it was just that. Burned out bulbs.
Good luck. Tell us what you find out.
#28
Welcome to the site I agree check the bulbs first, the hhr has a wide head lamp pattern so it's easy to drive around with a head lamp out and not realize it until the other go's out.
#29
Exactly, as many have discovered! All the more reason to check your headlights while stopped behind another vehicle at night -its pretty easy spot a burnt out bulb. Brake lights can be checked by looking at the reflection in the vehicle stopped behind you.
#30
welcome to the site.
Ok. Since you didn't bother to post what year your hhr is, i'll give you an answer based on a 2010 owners manual. The fuse locations are pretty much the same 06-11.
Fuse #65---dr. Side low beam
fuse #66---pass. Side low beam
relay #71---headlamp low beam
fwiw. You posted that you checked #64. I show that to be the fuse to the cannister in the emissions system.
