Mass Air Flow Sensor problems..... - Chevy HHR Network
Reply
LinkBack Thread Tools Search this Thread
Old 07-08-2012, 08:28 PM   #1
Images: 14
Angry Mass Air Flow Sensor problems.....
I have an 08 2LT with the 2.4/auto and ive gone through 2 Mass Air Flow sensors. The third time it acted up i took it apart and saw it was dirty and was able to clean it(i know your not supposed to do that but it worked for a good 6months now). Ive been having this problem for the past year(3 times) and now its acting up again. The motor surges and stalls, mostly when at a light but when it gets bad it does it even going 70. Eventualy it throws the MAF CEL and one for random misfire aswell. It doesnt matter if the motor is hot or cold. The only thing i could think of is i put a K&N filter in it about 1 1/2 years ago(ive cleaned it twice since i put it in and re-oiled it) and i wanted to know if anyone else is going through the same thing????
ChevyM84 is offline   Reply With Quote
Old 07-08-2012, 09:02 PM   #2
oneton's Avatar
Images: 33
Don't oil the filter.
oneton is offline   Reply With Quote
Old 07-08-2012, 09:19 PM   #3
Technical Moderator
Images: 66
Did you use MAF cleaner (available at your local auto parts store)? It IS the oil from the filter. Yes, almost everyone that installed an oil-able filter has the problem, it seems mostly from over oiling.
donbrew is offline   Reply With Quote
Old 07-08-2012, 09:22 PM   #4
Images: 49
I'm glad I visited this site before installing a K&N. I was very careful about the amount of oil on the filter and made sure to let it sit for a while before installing.
Breadfan is offline   Reply With Quote
Old 07-08-2012, 10:06 PM   #5
Images: 14
no I didn't use the cleaner......but I shall buy a new air filter tomorrow then and clean the airflow meter again......
Old 07-09-2012, 08:12 AM   #6
Technical Moderator
Images: 66
Quote:
Be sure to use the MAF cleaner, it is made for the job. Even touching the thing could muck it up, like any fine electrical filament.
Old 07-09-2012, 01:16 PM   #7
Images: 14
yup but that will have to wait cause the HHR was towed to the dealer because the lock cylinder they replaced on saturday stopped working.....
Old 04-28-2015, 02:28 PM   #8
Maf
we went to an auto parts store the HHR was acting up they said MAF was bad i was wondering if they make an aftermarket MAF?
aveojoe is offline   Reply With Quote
Old 04-28-2015, 03:41 PM   #9
Images: 54
Quote:
Yes. But the auto parts store you went to should have been able to answer that.
Fwiw. It may not be a MAF problem. If they read the codes and the code # instructed you had a bad MAF, that may be wrong.
Some codes #s can give a "false" positive about which part is defective.
firemangeorge is offline   Reply With Quote
Old 04-28-2015, 03:49 PM   #10
Technical Moderator
Images: 66
You can get rebuilt and new MAFs. EBay from China is a lot cheaper.
Reply
Thread Thread Starter Forum Replies Last Post
Mass air flow sensor artillery0811 Problems/Service/Repairs 14 02-20-2014 06:40 PM
Mass Air Flow part zabadubarbara Problems/Service/Repairs 19 08-13-2013 01:24 PM
Mass Air Flow wiring diagram 2009 ss Dieselracer Problems/Service/Repairs 6 11-17-2010 09:13 PM
Does anybody have the Mass Air Flow wiring diagram? Randy08 2.2L Performance Tech 4 07-07-2008 06:05 PM
Mass Air Flow Sensor 808jrh 2.4L Performance Tech 4 09-21-2006 06:50 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright © 2005 - 2013 Internet Brands, Inc. All rights reserved.
