My HHR Is Very Sick
Old 01-12-2017, 11:26 AM
  #31
NoHPbutalotofheritage's Avatar
Originally Posted by donbrew
As I said; A bad ref for the TPS and APP causes a fault, so the computer reduces power so you can't blow the motor up.
The computer can only control the fuel supply, that's why fuel trims are so hard to understand.
For instance; if you have a cracked flex pipe the #1 O2 sensor can read lean so the computer will increase the injector duty cycle causing a rich condition. Or, it can read rich so it reduces the cycle causing a lean condition. Either of those would cause the computer to go into reduced power mode if the conditions are right. Sometimes a crack will admit air (too much Oxygen) into the system making the sensor read rich sometimes exhaust gasses escape before they get to the sensor (not enough Oxygen) causing a lean reading.
Any sensor can short internally causing the entire ref circuit to go bad; engine power reduced mode. In a computer driven car everything that you used to call a switch is now a sensor. There are 2 ref circuits, the APP and TPS use both of them, other sensors use one or the other.
Many faults can cause a reduced power mode, the message tells you that it is activated, not that it is sensing a reduction in power.
Much more complicated than that, but for us amateurs enough.
100% agree and dead on, I just would prefer my engine to blow up first before reduced power mode kicks in... just a personal preference
Also, when TPS sensors (throttle and pedal) work, it's awesome. When it doesn't, it makes your life hell. Tbh, I'm glad it was a bad manifold in my case, rather bolt on a manifold and be done.
NoHPbutalotofheritage is offline
Bushmaster11B
Drivetrain (Excluding Engine)
10-18-2012 05:58 PM
sunbound
04-18-2010 12:36 AM
SSmokinZ06
22
02-14-2010 09:33 AM
Wackaloon
01-07-2008 10:40 AM
crowbar
04-07-2006 09:52 PM
Quick Reply: My HHR Is Very Sick
