My HHR won't start after hit
Hi all,
I was driving and had an oopsie moment and hit the curb and side rails. I messed up my tire and the front axel seems to be damaged as well, all that I can fix. However, the car won't crank. the battery has charge and the key turns, but nothing, not even the slightest crank.
Has anyone ever seen this? Any ideas what to look into?
Thank you
Thank you
all the connectors - they can be disconnected from the blow.
Generally an electrical problem with a high probability.
It would be nice to get more information.
What happens when you turn the key? Whether the lights are on the dashboard? Can you hear the sound of the fuel pump by turning the key?
Right now when you turn the key all the way nothing happens, not even the slightest attempt to start, no crank, nothing.
kick in the rack - a vibrating effect on the steering column - the egnition lock broke / "switch off" from the electric mains
some wire could break away from its place
bluedograbbit2
06-01-2013 11:27 AM
