need wiring diagram for 08 power steering. thanx
Old 04-22-2012, 08:22 PM
lisamoore4872's Avatar
power steering fuse under the hood keeps blowing several times a day. any ideas????? please help......
lisamoore4872 is offline
Old 04-22-2012, 09:19 PM
Repeated fuse blowing is usually an indication that the power steering motor is failing, when they go bad, the current draw from the motor can exceed the rated amperage of the fuse...then "pop" you've blown another one.
Have you been getting any power steering fault messages on the DIC?
843de is offline
Old 04-22-2012, 10:37 PM
messages do display.....usually the radio cuts out first, the i lose all power to EVERYTHING in the car.
Old 04-22-2012, 10:44 PM
Yeah that's a bigger problem than the power steering by the sounds of it, if you want to, send me a PM with an e-mail address and I can send you the wiring diagram for one of these critters and the troubleshooting section of the service manual in PDF form. Can't attach them here on the forum, they exceed the file size limits, and a few other things.
It'll be mid morning until I get to my office so they won't come through first thing.
843de is offline
Mercury
11-22-2019 09:13 PM
riveratx25
10-07-2018 08:02 AM
hvrod
02-07-2014 02:54 PM
AleksT
7
01-20-2014 11:15 AM
cannuck
06-27-2009 10:50 PM
Quick Reply: need wiring diagram for 08 power steering. thanx
