Need Help Car Won't start..Think its in security lockdown. - Chevy HHR Network
Reply
Thread Tools Search this Thread
Old 03-18-2009, 10:24 PM   #1
Hey guys first time really posting on the site. Have been searching but could not find an answer to my problem. I recently put back in my after market system in my car. The previous time i installed it no problems at all this time around i put the system back in wired everything up but now the car will not start. It clicks but no start up at all. When i look at the dash lights it shows the car symbol with the lock and the lock symbol is locked. I have no idea what to do now there was a burn smell as well that i don't know if that could be causing a problem. If the car is in lockdown mode what do i have to do to get it out and be able to start the car back up. I don't have any back up keys or warranty on the car so any help would be greatly appreciated.
UrbanStyle55 is offline   Reply With Quote
Old 03-18-2009, 11:02 PM   #2
Images: 20
try switching the stock HU in. or check your wiring as well
masterchief1112 is offline   Reply With Quote
Old 03-18-2009, 11:14 PM   #3
Did that put the stock HU back in and even diconnected the battery for 10min and still nothing the car when i turn the key to the on position keeps showing me the lock symbol which makes me believe its in a lockdown mode. Anyone know how to get it out
Old 03-18-2009, 11:16 PM   #4
oneton's Avatar
Images: 33
Relearn the Key, I have been trying to find the post on how to do it, no luck.
still looking
oneton is offline   Reply With Quote
Old 03-18-2009, 11:25 PM   #5
oneton's Avatar
Images: 33
Old 03-18-2009, 11:31 PM   #6
Will try this, any idea why this would happen?
Old 03-18-2009, 11:42 PM   #7
Just tried it and nothing still showing the lock symbol and just noticed theres no outside temp on my gauge cluster
Old 03-18-2009, 11:53 PM   #8
Its not the Key................
The wifes HHr did the same thing the radio wouldn't work the car woun't start the lock light blinks some times fast and the car makes a clicking if you try and start it but it wont start. called the dealer they told me that since I took out the radio it wasn't covered under the warranty and would run around 200 to reset the computer. I was tring everything diconnected the battery for 10min and so on......
what worked for me was to run the battery down tell the lights don't come on by leaving the door open you will know if the battery is dead after that I tried jump starting the car and it worked started right up. dont forget to leave the back open to get to the battery or you can jump it from under the hood.
Iceman is offline   Reply With Quote
Old 03-19-2009, 12:03 AM   #9
Thanks Iceman i will try this tomorrow and pray that it works.
Old 03-19-2009, 12:27 AM   #10
Found a little more info for you I dont think its the key but you never know
If i was you I would try the first post I made if that doesnt work here is how to reset the key.............
The Tech II computer is the easiest, but there is a 30 minute procedure.
GM makes it take that long to deter thieves.
Not many of them are going to sit in your car for 30 minutes to steal it.
30 Minute Relearn Procedure
Use this procedure after replacing the following components:
The PASS-Key III (PK3) keys
The BCM
The PCM
Important: This procedure is not available on vehicles equipped with option code (Z49).
If replacing a BCM with an GM SPO replacement part, perform the procedure to setup a new BCM prior to the 30-Minute Relearn Procedure.
With a master PASS-Key III key, rotate the ignition to the CRANK position.
Observe the SECURITY telltale. After approximately 10 minutes, the telltale will turn OFF.
Turn OFF the ignition, and wait 5 seconds.
Repeat steps 1-3 two more times for a total of 3 cycles or 30 minutes.
Important: The vehicle learns the key transponder information and/or passwords on the ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
With a master PASS-Key III key, start the vehicle. The vehicle has now learned the key transponder information and the PCM has now learned the fuel continue password.
With a scan tool, clear any DTCs.
Source(s):
GM Guy
Reply
Thread Thread Starter Forum Replies Last Post
HELP! Car Won't Start/Security Light Stays On HHRNewbie Problems/Service/Repairs 15 08-07-2016 08:37 PM
Security Issue budzone Problems/Service/Repairs 3 01-27-2014 02:17 PM
Security lockdown... Codysseus Problems/Service/Repairs 14 12-31-2009 11:05 PM
Pass tag security catdaddy137 General HHR 0 02-12-2009 03:06 PM
PC security...best software? jeffs396 The Lounge 18 12-15-2007 09:05 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 2005 - 2013 Internet Brands, Inc. All rights reserved.
