New Catalytic Converter Time! P0420 Code. New Bolt Size?
OK, so I have the new cat ready to bolt in place. Here is my question. What size bolts do I need for the 2 bolts that are located near the resonator? I would like to buy 2 new nuts and bolts to have on hand BEFORE I get knee deep in the sh1t pile.
Also what length do I need to have them.
Also, When I got the new Cat, they put the shipping labels and plastic pouches directly on the cat. Is there a good, easy way to get this off, or should I just let it BURN off?
What would you do.
Thanks for the bolt info. I'd rather start the project knowing that I have replacement bolts, JIC I break one, which will most likely happen. Unless the last mechanic to change it used anti-seize.
What would you do.
NxlKing2304
02-14-2014 07:41 AM
themoodman
10-29-2010 11:50 AM
