No sound from left speaker
Old 03-09-2013, 03:45 PM
Monty's Avatar
My left speaker is very faint. Is this a speaker or radio problem. It's stock 2008 radio.
Monty is offline
Old 03-09-2013, 03:53 PM
Technical Moderator
The driver side speaker is a common failure, due to water infiltration. If the balance is set right, that is the most likely. I'll bet your next complaint will be "no warning chimes".
donbrew is offline
Old 03-23-2013, 12:12 AM
hhrumadbruh's Avatar
put some polk marine rated 2-ways in the doors. maybe even cut the tweeter off so it's just a mid range driver
hhrumadbruh is offline
Old 03-23-2013, 08:49 AM
Technical Moderator
When mine went bad, oddly enough the cones were in good shape it was the coils got corroded.
donbrew is offline
Old 03-25-2013, 02:34 AM
raffmanlt's Avatar
Good post I will have to check mine I thought I had bad electrical connection.
raffmanlt is offline
Stryker
12-08-2018 02:58 PM
oliver_cfc
03-25-2015 03:30 PM
GinaM
05-25-2014 09:50 AM
RICK167448
Maintenance and Upkeep
10-10-2011 02:10 PM
jgoldwood
04-20-2010 08:43 PM
Quick Reply: No sound from left speaker
