Fuel door not opening like it use to
Old 01-09-2014, 04:06 PM
MCHHR's Avatar
I bought my HHR about 5 years ago and slowly over time my fuel door doesn't pop out like it once did. It still makes the click noise and holds the door shut when I press it, but when I press to pop it open, it opens ~1/16th of an inch and I have to use what little finger nails I have to get it open. I want it to really spring open like it did before.
Does anyone know if there is an adjustment for it to pop it open or will I just need to get a new spring for it? Sorry if this has been asked before. I tried searching the forums but didn't have much luck finding what I was looking for.
Thanks.
MCHHR is offline
Old 01-09-2014, 04:48 PM
Technical Moderator
I would try a spritz of WD-40, or whatever spray lube you swear by. I'm not sure there is a replaceable spring, more likely a bit of plastic.
donbrew is offline
Old 01-09-2014, 10:06 PM
Lucky's Avatar
X2 I would lube it first. If that don't work here a thread for the spring popper
https://www.chevyhhr.net/forums/problems-service-repairs-42/fuel-door-popper-37065/
Lucky is offline
Old 01-09-2014, 11:51 PM
Good find on the "Popper" thread Lucky.
Might want to paste the popper part number into whopper's parts thread.
843de is offline
Old 01-10-2014, 12:15 AM
Lucky's Avatar
Done
Lucky is offline
Old 01-10-2014, 12:10 PM
GM part # 20912532 will fix the issue.
Oldblue is offline
Old 01-10-2014, 01:07 PM
Blue_SS's Avatar
Be careful about using WD-40 on this. It gums up after a while and makes problems like this worse. Stick with an oil or graphite would be my advice.
Blue_SS is offline
Old 01-14-2014, 03:06 PM
MCHHR's Avatar
Haven't been able to check this since I posted. I'll try the lube and see what she does. Appreciate the tips everyone!
MCHHR is offline
Haunted_Hot_Rod
03-04-2012 09:02 AM
HHR_carnatic
Maintenance and Upkeep
02-28-2012 08:29 AM
dhansen871
06-12-2011 09:30 PM
Ken6432
03-03-2010 03:33 PM
Krusty
04-09-2008 09:19 AM
Quick Reply: Fuel door not opening like it use to
