Oil Leak from Somewhere
check your axle seals..common problem
Check your axle seals. I had one side leaking, looked like it wasnt seated all the way. Took a flat head screwdriver and hammer and lightly small increments tap the the metal part of seal inward and no more leaks. Becareful you could damage seal. For me was a quick fix. I called the dealer for axle seal replacement $150 bucks one side.
