P0121 problem
P0121 problem
We have been getting a p0121 code, so we cleaaned the TBS. Got worse, idle went up, so we replaced it and the pedal postion sensor. Same problem, idle at start is at 3-4000rpm,, goes down in drive but when you accelerate goes back up. Any suggestions?
Welcome to the site, P0121 has a relation to the harness rubbing .
As per
https://www.obd-codes.com/p0121
Check the wiring harness for chafing against the bracket under the EVAP valve.
As per
I'd guess at either a broken wire or a bad MAF.
Sounds like The #1 signal wire is not connected somewhere between the TB and the ECM.
Are there any more codes or things you didn't think were relevant?
06gray2ltHHR
2.4L Performance Tech
08-01-2009 10:45 PM
Black Rose
12-07-2007 11:28 AM
