P1174
Old 03-22-2011, 08:41 PM
1970judge's Avatar
07, 2.4. Code will be the same regardless. Not sure why this matters? The questions has already been answered anyway. I was just stating, it has gotten worse since December.
1970judge is offline
Old 03-22-2011, 09:03 PM
Spozo's Avatar
Because TSB 08-06-04-001B for P1174 applies for the 2.4l engine but not the 2.2l, and only in model years 06 and 07. Glad you had your questions answered.
Spozo is offline
Old 03-22-2011, 09:35 PM
1970judge's Avatar
Good to know. Thanks!
Old 03-22-2011, 09:43 PM
db/sb's Avatar
Originally Posted by 1970judge
Came back today, for the first time since December. It threw the P1174, and a misfire code on cylinder 2. Looks like injector two may be failing. It is smoking a little on cold start up as well, white smoke that smells like pure gasoline. Going through a rough couple of weeks here lately.
Which misfire code did you get for cylinder 2, P0302?. I only ask because misfire codes usually have to do with ignition so that doesn't necessarily indicate a failing injector. It could be that but it also could be a faulty spark plug or wire, a faulty coil, a faulty oxygen sensor, a burned exhaust valve, a faulty catalytic converter, poor compression, or even a defective computer.
db/sb is offline
Old 03-22-2011, 09:57 PM
1970judge's Avatar
Yeah I know, the other situations. But the two codes at once would lead me to indicate that 1) it has to do with the injector or 2) the injector acting up its self could have caused the plug to lean foul or fuel foul.
Old 03-23-2011, 06:58 AM
db/sb's Avatar
Yeah, after I typed that, I realized that I hadn't considered the other code (P1174).
db/sb is offline
Old 11-20-2012, 08:20 PM
1970judge's Avatar
So almost 2 years later, this code came back on the way home the other night (6 hour drive). I erased it, and it has yet to come back. It did not show any signs of running poorly either. TSB shows injectors, but I find it hard to believe, because of the long interval.
Old 10-13-2014, 12:25 PM
jdevries's Avatar
Do to the age of the post I'll post a new thread, but I get the same thing. Very intermittently it will throw code P1174, and ONLY when it's been driven at highway speeds twice in the same day. I typically use the same stretch of highway every Saturday and when I'm on my way home I can predict within a mile of when it will come on. When I drive it locally and after 4 or 5 starts the light goes back off.
jdevries is offline
Old 10-14-2014, 05:38 AM
interrex's Avatar
I am getting the sane code 145000 miles 2007 panel van 2.4l
interrex is offline
Old 10-14-2014, 06:33 PM
Snoopy's Avatar
See ChevyMgr post above. Common problem with many 2007's and the 2.4 ltr. engine.
Also do a search regarding the window switches and the gas fill location. Many discussions on each of these. So your complaint is not original.
Snoopy is offline
jschmieding
01-02-2019 08:20 PM
jdevries
01-02-2015 12:09 PM
justinrsetzer
05-01-2012 02:44 PM
sunbound
08-29-2008 11:07 AM
Quick Reply: P1174
