Passenger door latch
Old 12-26-2013, 05:51 PM
Babbette's Avatar
Question Passenger door latch
passenger door is temperamental ...sometimes it will latch and stay shut and sometimes it is like the latch just does not catch and keep the door closed... any remedies out there? took it apart and finally got it to stay shut so I can't use that door till I get it fixed...
Babbette is offline
Old 12-26-2013, 06:49 PM
Lucky's Avatar
Most door latch problems are from rust/corrosion on the levers/linkage on the latch. There is a tsb on latch diagnostics with some pictures that may help you although the tsb does not state your exact problem. Type tsb in the search box and click on official tsb thread then see post 127.
If it is rust/corrosion of the latch you can try to free it up with up blaster or wd40 oil however if my latch was not latching the door I would probably replace the latch for the safety concerns instead of trying to free up the rust.
Lucky is offline
Old 12-26-2013, 08:39 PM
The GM pn for a new latch assembly is 20791793.
It has a dealer list price of $139.30
But a Google search will turn them up for anywhere from $105-115.
843de is offline
arp
07-20-2019 12:12 PM
Babbette
01-11-2014 07:27 PM
Leonard
05-29-2012 10:34 AM
GriffingR
12-31-2011 06:14 PM
pitbull76
01-25-2009 04:38 PM
Quick Reply: Passenger door latch
