steering collum noise
Old 08-03-2013, 09:48 PM
pdmorris1's Avatar
I have a 2006 LT with 134K on it. I have a noise in my steering collum when I hit a bump. It sounds like it is inside the vehicle . Like something loose on the steering shaft. Anyone have an idea. I heard they had problems with the steering shafts back then
pdmorris1 is offline
Old 08-03-2013, 09:56 PM
Technical Moderator
Use the search tool up on the top banner. There are at least 4 different things off the top of my head. sway bar bushings, sway bar links, intermediate shaft, Lower Control arm bushings, rack & pinion, tie rod ends and more.
donbrew is offline
Old 08-04-2013, 07:38 AM
cpcook's Avatar
Has anyone ever posted a HOME repair for the intermediate shaft?
Seems like replacing the whole shaft from the stealership is the only remedy.
I'm wondering if some epoxy or glue added somewhere along the shaft might work .
cpcook is offline
Old 08-04-2013, 08:40 AM
skyline26's Avatar
your going to have to live with the noise...i have replaced the column under warranty plus other suspension components and i still have that rattle noise
skyline26 is offline
Old 08-05-2013, 08:41 AM
Zagohhr's Avatar
Same here
Zagohhr is offline
anthony303
10-25-2018 10:35 PM
skyline26
05-06-2014 09:39 PM
Bahta
07-26-2010 05:31 AM
Rikki Sixx
06-01-2010 07:22 PM
dlmhhr
03-09-2009 11:05 AM
Quick Reply: steering collum noise
