possible thermostat or temp sensor issue
Old 01-09-2011, 10:53 AM
Telepsychic's Avatar
I've been having a problem with my temp gauge and temp display. It only happens when the outside temp is at or below 55 degrees or so. When the car is cold, I start it and drive for approximately 12 minutes then the temp gauges stop working. If I turn the car off for about 45 minutes then restart, the temp gauges won't work for about 4 minutes, then come back on and work good the rest of the day. Occasionally after the stop/restart interval the gauges don't come back up for the rest of the day and that's when the CEL displays. The codes say it MIGHT be a bad thermostat or it could be a faulty temp sensor or the electrical connections. This is the 2nd winter this has been going on. In the summer it works fine.
My question is, where is the temp sensor on the 2007, 2.2L engine? I don't have a repair manual otherwise I would look it up. By the way, the engine doesn't overheat.
Telepsychic is offline
Old 01-09-2011, 03:31 PM
Just changed out the thermostat. That was not the problem. Temp gauge & digital temp display still not functioning.
Old 01-09-2011, 05:27 PM
Lucky's Avatar
disconect the battery for about 3 min. this will reset the modules and clear the codes. do this as a first step if the problem is still there then you will need to start checking sensors and wiring.
Lucky is offline
Old 01-11-2011, 05:21 PM
Yesterday I had the codes cleared by Pepboys. That code hasn't come back. Thanks.
megsaz80
11-05-2020 01:51 PM
NxlKing2304
05-29-2015 05:22 PM
oldracer
Maintenance and Upkeep
07-04-2014 10:53 PM
dinobass
11-20-2006 03:18 PM
joesblackhhr
2.4L Performance Tech
31
07-20-2006 04:28 PM
Quick Reply: possible thermostat or temp sensor issue
