Power steering problem
Old 07-15-2007, 06:37 PM
w_leroy's Avatar
Smile Power steering problem
Hello, I just have one question some far. My neighbor has an HHR and recently left her lights on draining her battery. Since then her power steering is out in the car. Has this happened to anyone before? Any help would be apprciated ciao!
w_leroy is offline
Old 07-15-2007, 06:41 PM
First, Name:  welcome4.gif
Size:  5.6 KB to the site!!! Second, did someone jump the car? If so, check out this thread: No Power Steering. So are they selling the HHR in Europe already?!?
HillsdaleHHR is offline
Old 07-15-2007, 07:01 PM
Yup, sounds like sombody goofed when jumping it. The ground for jumping in the front in one of the bolts for the top of the struts. I you use what looks like it SHOULD be the ground on the fuse box, the fuse for the power steering blew. Simple fix; get a new fuse from a dealer. (Unless, you are in Europe, which means getting a fuse may be a big deal!)
GDZHHR is offline
Old 07-15-2007, 09:07 PM
Black Rose's Avatar
Shouldn't be an issue getting a fuse.
Should be able to get them at an Opel dealership.
Black Rose is offline
Old 07-15-2007, 10:14 PM
Hills and GDZ pretty much hit the nail on the head.
jx3 is offline
Old 07-16-2007, 08:18 AM
SandyBeach's Avatar
So if you have to jump start an HHR, should you connect to the battery in the back to avoid this problem?
I tried to use my HHR to jump start my van but it didn't work. The battery was wasted. Glad I didn't blow any fuses in the process.
SandyBeach is offline
Old 07-16-2007, 08:34 PM
Snoopy's Avatar
No...not necessarily.....
The usual hook-up under the hood. Red to Red....remember the red correct terminal under the HHR hood is marked with a "+". The negative terminal is NOT RED or CAPPED IN RED. The negative terminal connection, is one of the strut tower bolts/nuts marker with the "-" (drivers side).
Also, your Owners Book provides some information and direction.
Snoopy is offline
Old 07-24-2007, 12:09 AM
w_leroy's Avatar
Thanx, Hillsdalehhr. I will check the fuse box oday. I just injured my knee so I have been out of commission for a few days. My friend bought it in the States. But, yes you can get them through the American system here in Germany. Ciao!
w_leroy is offline
Old 07-24-2007, 12:13 AM
w_leroy's Avatar
Smile
Thank you for such a speedy reply. I will get the fuse from Opel today. The Opel dealer is affiliated with Chevy so it should not be a problem. I love these forums such great information. If I would have just taken it to the Dealer it would have been about 45 or 50 euro. Ciao
w_leroy is offline
Old 07-24-2007, 12:14 AM
w_leroy's Avatar
Thanx for your help with the power steering prob. Ciao
w_leroy is offline
Quick Reply: Power steering problem
