internal computer module
Old 06-23-2012, 09:19 AM
Brewer13's Avatar
Anyone have their engine cut out while driving---first the dash says engine power reduced then goes to engine disengaged. Did a scan and it said internal computer module. Anyone know what thats gonna run?
Brewer13 is offline
Old 06-23-2012, 09:33 AM
What was the code? Ie: P1224
whopper is offline
Old 06-23-2012, 09:35 AM
Well if the ECM has failed you're looking at somewhere between $350-400 for a new one, or around $100 for a used one, plus diagnostics and labor unless you do the work yourself.
What codes are showing up? Also check the underhood fuse box, make sure all the fuses and relays are firmly seated in their respective sockets, plus check the fuse box itself to make sure it isn't loose.
843de is offline
Old 06-23-2012, 09:40 AM
Brewer13's Avatar
OK thanx guys
Brewer13 is offline
heatherbrooker
12
08-21-2014 09:07 AM
rick_rob
10-21-2012 09:15 PM
SFBay
Maintenance and Upkeep
01-17-2012 02:45 PM
geg
05-18-2010 11:17 AM
GDZHHR
11-23-2007 12:09 PM
Quick Reply: internal computer module
