right front wheel area thumping under hard braking
Old 07-13-2009, 10:17 AM
mrkil's Avatar
Okay here is the deal.
When I was driving on the highway yesterday, my hhr ls started making a thumping noise when I press the brake pedal moderately hard. It sounds like a thumping coming from the front right wheel well, but it's only intermittent.
any thoughts are appreciated
Thanks
mrkil is offline
Old 07-15-2009, 07:36 AM
mrkil's Avatar
hmmmmm
no one huh
mrkil is offline
Old 07-17-2009, 01:14 AM
TiggersHHR's Avatar
Does it make the sound when the brakes are hot or cold?? If it only happens after the brakes have heated up – then you might have a rotor that is starting to warp. Another option would be that you have a brake pad or a caliper not working properly.
TiggersHHR is offline
Old 07-17-2009, 07:57 AM
mrkil's Avatar
usually only after a hard braking incident
and the it disappears after about 15 minutes
mrkil is offline
Old 07-21-2009, 01:05 AM
TiggersHHR's Avatar
Do you get a slight pull to the right in the steering wheel along with the thumping? If so I would most likely go with a caliper not releasing or not working properly. One note - I had mine in for a hub bearing assembly replacement. When they went to take the calipers off - the threads in the caliper came out with the bolt!! They say corrosion - I say not install properly in the first place. Good luck
Old 07-27-2009, 09:03 AM
mrkil's Avatar
there is no pull to the side at all when braking
mrkil is offline
dhargett346
06-29-2014 10:49 AM
hhrumadbruh
05-11-2014 05:47 PM
del1933
11-17-2013 04:11 AM
emorris
08-21-2013 08:58 AM
TEKNOnaut
15
10-14-2012 12:13 AM
Quick Reply: right front wheel area thumping under hard braking
