2009 chevy hhr
Old 11-21-2012, 01:23 PM
sexyclw's Avatar
Question 2009 chevy hhr
I have a 2009 Chevy hhr. It is running hot( very bad) and the heater has. Stopped working. What do you think is the problem?
sexyclw is offline
Old 11-21-2012, 02:01 PM
solman98's Avatar
My first guess would be stuck thermostat, closed at that. But since your heat isn't working, does that mean no heat or fan not blowing?
solman98 is offline
Old 11-21-2012, 02:35 PM
Technical Moderator
Did you consider checking the coolant level?
donbrew is offline
Old 11-21-2012, 03:56 PM
badassbowtie's Avatar
those two symptoms sounds like a waterpump...but a thermostat stuck closed would mimic a broken waterpump
badassbowtie is offline
Old 11-21-2012, 06:23 PM
IMPALADAKID's Avatar
how many miles on it? I think thermostat and water pump are covered under the 5/100 warranty. But check the coolant level first.
IMPALADAKID is offline
Coyolmitl
06-13-2015 05:54 AM
TyroneMD
02-03-2010 11:11 AM
Quick Reply: 2009 chevy hhr
