Rear wiper switch
Old 04-17-2012, 07:24 PM
solman98's Avatar
Rear wiper switch
Noticed tonight when I went to pick up my daughter from gymnastica the rear wiper would not run in the slowest of the two speeds. Occasionally it would run 1 swipe, but not the delays. It would in the faster of the two, delay and all.
Anyone that has removed the rear wiper have a un-needed switch lying around?
solman98 is offline
Old 04-17-2012, 07:50 PM
87silver's Avatar
Mine's un-needed, as I don't use the rear window scratcher, but I want to keep the car intact, because I expect to retain it until my kids inherit it.
I checked on e-bay and there's 2 currently listed at $17.50 and $14.00
http://www.ebay.com/sch/i.html?_from...All-Categories
87silver is offline
Old 04-18-2012, 06:10 AM
solman98's Avatar
I saw the 2 on ebay and will get one there is it comes to that. It actually worked this morning and I realized that it was the faster speed that wasn't working yesterday. Switch is going out, but not in any real hurry.
solman98 is offline
Old 04-19-2012, 12:07 AM
IgottaWoody's Avatar
My rear wiper ONLY works in intermitten mode...no matter the position and at same timing...never use them so never worried,
IgottaWoody is offline
Old 04-19-2012, 05:39 AM
solman98's Avatar
Both setting on the rear wiper are intermitten, one is just a faster delay then the other.
solman98 is offline
Old 04-19-2012, 06:29 PM
Technical Moderator
May not be the switch. There is a circuit and relay involved. Tom Hanks made a movie about the intermittent wiper guy, point being it is not "just a switch".
donbrew is online now
Old 04-19-2012, 11:32 PM
Never looked into it so I figured one way was on and the other intermittant...dont believe they worked right from day one, both positions run the same
Old 04-20-2012, 08:32 AM
barfan1's Avatar
Mine wil work fine and then all of sudden the wiper will just stop and I have to toggle the switch off and on to get it back working. I believe the resistor for the time delay is in the switch and it is just worn and going out, much like blower motor resistors get. If the relay was bad I would expect no operation or very erratic operation, like it works fine and then the next day nothing etc.
barfan1 is offline
chuckkarate2
02-20-2012 08:51 PM
richie6
07-06-2008 06:55 PM
crowbar
45
08-10-2006 09:44 PM
Quick Reply: Rear wiper switch
